Continental Camper Tyers
Leicestershire
Beginners, got Doggy the van - March 2014
I have 4.5T AutoTrail MoHo with Continental Vanco Camper 225/75 R16 116R CP.
Hard to fine (now in Bulgaria then Romania & Croatia.
Did Continental stop making them?
Recommendations for replacement two front Tyers please.
They still make then as far as I know.
But I changed to decent quality correct size van tyres with the correct load rating.
Has made a huge difference to ride quality.
Thanks Phil. Will that
ContiVancotact 100
Four Season 2
225/75R 16 C 121/120R
will do although load rating higher?
And just to throw petrol on the fire of an associate to this thread.
ie. What should my tyre pressures be?
Yesterday, a DHL van was parked beside us in a car park.
It was a MB Sprinter. It was shod in Continentals.
Alongside the front tyre was a sticker saying '44psi' On the back panel by the wheel arch was '65psi'.
If you have Conti’s and axle weights speak to Conti tech dept, they are very helpful. I usually run around 4 bar all round to allow for max weight and mine (Sprinter 316 based) runs well 👍
ContiVancotact 100
Four Season 2
Higher load rating will probably allow you to reduce tyre pressures.
If you know your actual axle weights when loaded look up the conti Web site there is a table to look up for tyre, size and weights.
PS. I have Toyo observe van winter tyres on mine all year. Slightly higher load rating.
Gives smooth ride and good grip, although they will wear quicker than the conti campers I had previously.
Continental stopped producing Vanco2 tyres a while ago, these were the tyre fitted to our MH by either Chausson or Ford. I was very pleased with them at 8 years old / 40,000 miles still had 6mm tread left. Continental tech dept advised me for 3.3B all round after we weighed the MH on a weighbridge and supplied the actual figures.
Now fitted Continental VancoCamper and so far equally pleased and they run quieter also.
