Comfortmatic Problem (1 Viewer)
DumfriesDik
883
4,216
SW Scotland
Pilote P740GJ
Newbie
I have lost six gear. Otherwise performing perfectly.
Is there a gearbox dipstick?
Anyone had similar and have a solution??
lorger
9,492
88,691
Dumfries
Knaus Sun 650MEG
No idea what it could be but to help others have you lost 6th in both auto and manual mode?
DumfriesDik
DumfriesDik
883
4,216
SW Scotland
Pilote P740GJ
Newbie
Yeah. It’s gone in all modes, manual, auto and E mode.
I’ve tried giving it beans as well but alas still no 6th. We have turned off/on, no change.
And everything else seems fine. No strange sounds or jerkiness, perfectly normal.
Cheers.
Feb 19, 2020
1,270
1,386
North Ayrshire
Adria Matrix 670SC
Newbie
No gearbox dip stick it's not a normal auto with torque converter that needs automatic transmission fluid. Sounds expensive, what year is it? You don't have the hill button pressed do you?
Badknee
7,282
389,597
notloB
Vantage Neo
Living the dream.
There is a reservoir over on the right low down near the air cleaner housing. Check out YouTube vids it’s on there.
Good luck 🤞
Dec 2, 2019
3,506
8,048
South Lincolnshire
Rapido 7065+
Broken most bits now
Plug into Multieciuscan and clear any transmission codes and hopefully it will be fine.
DumfriesDik
DumfriesDik
883
4,216
SW Scotland
Pilote P740GJ
Newbie
sorry for the slow reply. We’re heading home tomorrow and I will give a fuller explanation then.
We’ve been to a Fiat Professional in Eire and have some codes. Part not readily available here.
Will have Fiat Glasgow order up part and fit when it’s here.
It’s a right shame.
DumfriesDik
DumfriesDik
883
4,216
SW Scotland
Pilote P740GJ
Newbie
I have the paperwork and I am at home now - so much easier on a PC! For me anyway.
Right, the error codes:
P2915-72 Fault on gearbox subsystem (Engage failed) - actuator stuck open
P2919-64 Transmission Control Unit (CSC Fault) - Signal plausibility failure
Doesn't sound expensive does it?! Everything seems to be multiples of £500 with the motorhome. :(
Dec 2, 2019
3,506
8,048
South Lincolnshire
Rapido 7065+
Have the codes been cleared and then reappeared? If not this is what you need to have done first.
Feb 16, 2013
18,957
46,942
uttoxeter
ambulance conversion
50 years
Thanks IRHP the fluids were checked in Ireland and normal.
dunnah01 This is something I can not do but I hope it is that simple.
Code readers are not dear in the great scheme of things, any motor factor or eBay/Amazon fill fix you up from £20.
DumfriesDik
DumfriesDik
883
4,216
SW Scotland
Pilote P740GJ
Newbie
I appreciate that chaser but it is something I am not comfortable doing. The van is booked in for next month, so I'll leave it until then.
Thanks again everyone.
Feb 16, 2013
18,957
46,942
uttoxeter
50 years
You can't hurt anything, it will just come up with a fault or not, if it comes up with a fault code then asks do you want to remove the code, if you do it will or won't but no harm done either road.
Sep 17, 2017
4,903
8,703
Birmingham, UK
A-Class
My understanding is, as it's just a robot doing the gear stick for you, it's a manual box underneath. So there's a servo actuator that gives you the equivalent of left and right on the box. And as you can get you 5th, that's not an issue. And another actuator to slot it forwards and back into the odd and even gears. And as you're getting 2nd and 4th, that actuator is working fine too.
Which implies that it's a mechanical issue preventing 6th gear from sliding in. It could just need some adjustments on the linkage... or it could be more 'metal shavings' type expensive. 😬
Feb 22, 2008
12,180
44,230
Norfolk
Hymer B544
Since 2004
Just checked my comfortmatic clutch fluid reservoir and it’s approx 15mm from top.
I have never checked it as there is no warning label and wasn’t aware it was there and assume that the dealer that services it annually does check and top up if necessary.
It’s a tiny reservoir.
