Evenin' All
As some of you may recall, I'm replacing the 12 volt system in a friend's motorhome. I am now coming towards the end of the commissioning phase and have found a problem with the Truma heater. When removing the front cover of the the igniter "fell" out. I'm unsure whether the wiring was attached very loosely or not at all. On this version of the igniter there are three wires, one which connects via a small female spade connector and two wires which push on to the posts towards the left of the battery compartment, all at the rear. Looking at exploded parts diagrams, it seems as though the connections to the posts should be by means of a 2-pin female connector. If anyone has such a heater, early 1999 vintage, I would be very grateful for guidance on how the wires should be connected as I can't see any difference in the cable colours.
Can anyone help, please?
J
J
