Hi all I have a Burstner Iexo 736 2019.had a bad gas leak develop and found that the pipe from the isolator valve on the manifold has no clips between the manifold valve to the hob itself. And vibrates whist driving. It is connected to a short pipe that in turn is connected to the three gas valves. Over time this short pipe appears to have distorted and the the seal has failed leading to a large leak. The particular hob appears to be no longer in production, the valves are available but out of stock but the pipe is not available. So £85000 motorhome three years old 15 months of which was Sorned (Covid) and down to me to repair at my cost. If this unit had been installed correctly with the pipe clamped I am sure I would not be in this position so I would suggest if you have a similar unit check it. From the photos the three very short pieces of pipe have broken off the end of the gas valves which has not helped I can only assume that was done during assembly, but as usual nobody’s fault.
