Cheapest 100W Mono solar panel
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
Jim Please move this post to more appropriate section if applicable?
I just thought with so many Funsters looking at solar panels or adding to their existing setups a thread about pricing for panels might be helpful?
Consider this a short summary from another post I had asking for reliable suppliers to the UK. To keep things simple this is solar panel only - no fittings or controllers.
E.G. Just found;
100Watt Mono panel - £62.90 Deliverted (Bau-Tech Germany). Item Number 263141333620
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=263141333620
100Watt Mono panel - £89.99 Delivered (Photonic Universe)
Jev88
- have you fitted these on your van ?
I'm looking to fit a couple on my PVC but with so many different makes on the market I get brain fog ?
Jev88
Hi. I want to try one and add it to the existing Chinese made panel on my roof (purchased from an upgrading Funster) .
Not had time to do it yet. It isn't as bad as you think.
Buy all bits, attach brackets to panel, prep roof, attach panel to roof, route cables to suitable spot, drill hole(s) for cables down into locker area from roof, cover entry point with gland and cover unit, secure to roof, route cables to controller, route another cable to battery. I have a battery under long bench, 150cm cable to wall cabinet, controller mounted inside cabinet, cable from roof drops down above. Also added a £3 volt meter to panel connection on controller to instantly see what voltage I have from roof (as my simple.controller doesn't tell you anything apart from red fault or green charging).
