Cheap Flair (1 Viewer)
funflair
19,355
30,244
Guisborough
MORELO palace
since 2012
What sort of tape to you use for that job. I presume you sikaflex then tape over top or otherway round.
I pulled the old tape off and checked the Sikaflex joint underneath and it was all good so left that alone then taped on top with https://www.eternabond.com/articles.asp?id=148 some of this, expensive but it been up there about 4 years and as good as new.
Martin
Edit, if you are going over to Polch in November I have some spare in the garage(y)
Oct 12, 2009
10,663
23,654
A Class N+B Arto 69GL
Since 2009
Martin
Martin
What a coincidence. I had not opened this thread before, but at about the time you posted I was on the roof of our Arto inspecting the joint between the main body and the overcab fairing.
Like you the sikaflex seems solid but the white tape has peeled off in some parts.
I am considering just taping over the existing sikaflex and have sent a request to eternabond to find out if it is available in Poland, if not where did you get yours? There seem to be several for different purposes - which one did you use?
A further question; where the tape has deteriorated the sikaflex has raised slightly in patches. Did you find this? If so did you ignore it and tape over regardless of the cosmetic effect? The other solution is to run over the top of the bumps with a Stanley blade or similar but I wonder about eroding the thickness and integrity of the seal - any thoughts?
Geoff
funflair
19,355
30,244
Guisborough
MORELO palace
since 2012
Hi Geoff
And by another coincidence I just happen to be at the van with ladders out,
Yes I believe it was a bit lumpy underneath but I just left as is, it was a job getting all the old stuff off from memory, this is the 50mm tape and you can see I have lapped it over to create a double layer over the joint. Sorry I don’t recall now where it was from but I know it was expensive.
Martin
Awayoflife
29
9
Brighton
Neismann birscoff flair
On and of for many years now permantley
Must be a product in uk that is similar surely.
CazPaul
Jun 30, 2011
7,241
20,128
Barnard Castle, UK
Concorde Concerto
EternaBond leak Patch is the best solution for leak repair.
Details:- 81 Illingworth Close, Mitcham, Surrey, CR4 3QF, UK Tel 020 8648 3866 (We stock all products)
All items posted by recorded post
Large Sizes
Large Size 10cm x 7.6m Large Size 10cm x 7.6m £44.99
EternaBond RoofSeal
RoofSeal makes a permanent water-tight seal. Fix leaks and crack on roof, concert walls, metal, plastic fibreglass,PVC , in and around caravan home etc
In come in Black, White and Grey Colour
EternaBond RoofSeal is the best solution for leak repair. The choice of professional roof repair specialists, on virtually all roof types including EPDM, TPO, hypalon, most PVC, modified, all metals, even copper and kinor coated metals, tile, wood, concrete, etc.
RoofSeal even works great on land-fill and pond liners. Our specialized backing has proven to be UV stable, even after 19 years in full sunlight. Our MicroSealant has a built in primer, which allows RoofSeal to BOND with the surface it is installed on. Perfect for resealing all roofs, regardless of the material.
* 700% guarantees RoofSeal will flex expand and contract in all conditions!
* Can be installed to -30 degrees C (with our EternaPrime).
* Sag rating of over 120 degrees C.
* 10-year warranty.
* Also great for tank repairs.
* Available in 10cm
* Thickness: 0.9mm
Colour
£44.99
Awayoflife
29
9
Brighton
Ok thanks I shall order some
