Chausson help
Rebel scum
Chausson 610 flash
just picked up our 2016 Chausson 610 flash, have a couple of questions, there is a fitted plate with the tv aerial socket on, does anyone know if this is connected to anything? And where I can locate the cable to connect to an aerial? Also have been told there is pre wiring for a reversing camera, anyone know where this is located? And can you fit any camera and monitor? Or will it have to be a dealer one? Have been trawling the internet for answers but not had any luck, look forward to any help offered, cheers guys
If it’s anything like the Pilote we had the camera cable had a very small 4 pin connector on both ends. Hunted high and low for the connectors and finished up cutting them off and grafting on the yellow and red ( power ) connectors so I could fit my own camera. Dealer wanted over £500 for a camera and screen. The other end was in the dash near the fuse box just curled up. I would have thought the aerial lead is connected to nothing. The Swift we had had a connector in the outside power entry box to fit an external cable to a comunial aerial like you find on C&MC sites.
Upvote 1
If it the same as my 620 there is a tv aeriel socket provided but its not connected to anything.. if it has a piece of co ax connected its just coiled up for connection to your tv amp if it long enough..
The wire for the reversing camera on mine came up the left side of the van and terminated in a coil between the two front seats.. it was grey with what looked like an rj12 connector on the end..
Andy.
Cheers guys will check it out this evening
