Changing from whale to shurflo
autosleeper
Is it easy to change from an onboard whale pump inside the tank to a shurflow outside the tank?
What are the advantages to doing this?
Are you changing from a microswitch system to a pressurised one. If not I cant see any advantage, an external shurflo pump is much noisier.
Its got micro switch only thinking of changing as had a problem with no water and could not get at the pump in the tank
You may need to cut a hole in the tank for a feed to the external Surflo pump unless the Whale pump already needs one
There is a clear and blue pipe into the tank with the whale pump attached
