Guest viewing is limited
Changing from rear view screen to double DIN - cable adaptor
Teesside
Burstner Elegance
None
Hi Folks, we have a 2014 Burstner that came with a single DIN head unit and a separate reversing camera screen. I have ordered a new pioneer double din head unit and want to move the rear camera feed to the head unit and get rid of the separate screen.
It is a Waeco camera and sip lay, with 20 pin connectors.
I have looked online but cannot find any adaptors that would allow me to convert the cable from the current connector to the pioneer unit? Anyone solved this issue? Thanks in advance.
I contacted reversing cameras uk. Chris was very helpful and suggested I follow the lead further. Sure enough there is a veritable forest of wired that connect into the 20 pin din lead. So there is a bit of untiring and re-wiring to do. So that’s a job for autumn.
Does your Waeco camera have two cameras ? IE it changes from rear view to reversing view when you select reverse gear ?
