In that case, you require a Jumbo REGULATOR.Ah, no I don't have a fixed regulator, mine screws directly to the bottle. Will the jumbo adapter fit to my regulator which is a UK Pol propane screw fitting?
It will work fine.Argh, it's getting complicated. I understand which regulator I require now, it's this one as per your photo. I would just have to swap the rubber tube over. However they only appear to be 29mbar, my van elderly van runs on 37mbar, I don't know if 29 mbar will work?
Ah excellent, I'll order up a regulator. Thanks for you helpIt will work fine.
Back in 2002 when they changed over from bottle fitted Regs to Baulkhead Regs. they got rid of the difference between Butane and Propane and went for 30mbar. No one really noticed the difference. It will work.
