The problem with the sound through the head unit is if it's a Pioneer if you don't turn the media switch off on the control panel it can flatten the starter battery overnight.Hi Lenny, just to let you know the main tv in mine does run from van battery, so when not on hook up I turned head unit off and watched tv for 2/3 hours and kep a eye on van battery gauge , also fitted my own tv in bedroom and run a wire from leisure batteries hidden under second floor up into bathroom cabinet , so can watch tv fire stick till the cows come home
Why's that? Are they fed up with all the adverts?.......... so can watch tv fire stick till the cows come home
Hi Lenny just wondering we are going to megeve soon , we will be on hook up on site , do you think it would be ok to plug a small 700 watt oil filled radiator in bedroom ??It says it has in the spec, have you not looked.
That will be fine it will only draw 3 amps.Hi Lenny just wondering we are going to megeve soon , we will be on hook up on site , do you think it would be ok to plug a small 700 watt oil filled radiator in bedroom ??
