Cargo Tie down track on Hymer
  • Thread starter Thread starter Chockswahay
  • Start date Start date
C
Chockswahay
Does anyone know where I can buy some extra fixing points for my van please?
They look like a commercially available tie down track, me and Missus Chocks are looking on line for them but somebody might already know where I can get some (?)
Ta
Hi, they are called Hymer Garage T Bolt eyelets. Got mine from Ebay, but they seem sold out at the mo... sorry I can’t help more... try a hymer dealer I suppose.
Brownhills used to sell them on ebay I think, so you try them. But, like all things Hymer, they were very expensive for what they were. .
When I researched them you could buy the eyebolts on line easy. The bit that goes into the track is called a Halfen insert I believe, which are used in the construction industry and are available. I ended up not needing any more so did not buy any. But you could have a search for those.
Good spot. But search ebay for eye nuts. Then search again for halfen bolts. May well get them cheaper.
I bought some 8mm (might have been 10mm) eye bolts from ebay and made my own inserts from some flat bar cut off into strips, drilled and tapped.
Edit - washers because I was too lazy to trim the too-long screws :rolleyes:
Thanks Chaps (y) As it happens I have just gone out to the van and taken these photos..... if possible I'd like to get hold of the complete fittings as shown. Also maybe ones that can fix permanently to a board that I can then use to separate some of the garage contents.
(oh, @Lenny HB ...... note the gas filler is done, new bottles arrive tomorrow (y):D2;))
They are used in disabled minibus conversions. The track in the floor is used to tie down wheelchairs.
Courtside conversions at Tiverton convert the bus so may be able to supply or point you in right direction.
