Tony68000
Hi, I've got a curious 'power panel' inside a cupboard on my Rapido. It's near to where the pop-up antenna would normally go.
I think the AV connectors feed to the front of the van for the stereo, that's fine. But what's the green power(?) connector above it for?
AUX.1
+APD
+MASSE (French for 'Mass' - I presume 'load?')
<Blank>. - could this be 0v?
I haven't put a meter on them, not sure if they are factory fit or something else. I could do with a good 12v feed to this area anyway, so could either remove the panel and get to the wires, or get a connector that fits.
Any idea what it is and if so, what each pin is for, what battery 'feed' it connects to (a guess is that 'Aux.1' is feed from the control panel 'Aux1' switch), and what amps I might be able to drive from it?
Thanks.
AUX.1
+APD
Thanks.
