No good if you are not on EHU.Why would you need one?
I thought the schaudt charged 80% leisure and 20% engine battery.
All sounds complicated, I had 3 x lithium Transporter batteries fitted while I watched, I was surprised that there was no change to onboard electrics, they told me the battery had its own electrics so not needed. had them on for about 3 years and no problem and they are brilliantLots on here about B2B can I fit myself to my 2017 Hymer? There seems to be lots of different models . If I can fit one which one should I get? 2 x 110 lithium batteries 2 x solar panels 2000 inverter.
You will just charge them at a fraction of their actual "capable" charge rate, or in other words you will have to drive longer to charge them properly.All sounds complicated, I had 3 x lithium Transporter batteries fitted while I watched, I was surprised that there was no change to onboard electrics, they told me the battery had its own electrics so not needed. had them on for about 3 years and no problem and they are brilliant
Hi SueWhy would you need one?
No wonder youre always late!B2B is the best way to get the most out of your lithium batteries.
Mains? No point having Lithium if you intend to be on hook up 27/4
Solar? well in the UK Solar is excellent for a 1/3rd of the year when you don't need much power, OK for 1/3rd of the year, when you need more power and useless for a 1/3 when you really need power.
This breaks down to Summer, with a bit of Spring and a bit of Autumn. Spring and Autumn & Winter with a bit of Autumn and a bit of Spring
