Burstner Ixeo Time waste water pipe
John Love
West Sussex
I’m a newbie
We have a 2017 Ixeo Time 726 which has a grey waste water pipe, it measures about 40mm diameter. I am looking for a suitable extension pipe to fit the outlet, anyone have any ideas on where to buy such a thing?
We got a convoluted type at The Range warehouse but garden centres are a good source
OK thanks. It’s the connector/adaptor that may be more difficult to source, the actual pipe is not the issue.
If its 40mm you could use a 40mm push fit waste connector or a 40mm multifit which is the white plastic compression fittings both available from screwfix
I had a Burstner and went to B&Q where I got a flexible connector for 40mm kitchen waste and then a length of 40mm waste pipe.
I left the flexible connector permenently attached to the length of the pipe. On site or at grey water drains I would then push the flexible connector on to the Burstner outlet pipe. Took seconds and worked very well.
I got my grey pipe from a pond supplier...... with a flexible connector as described above.
Thanks for all the tips, the flexible connector plus pipe seems the best solution. Really appreciate all the responses.
When we had a 2014 Ixeo 726g it came with
a 1metre waste pipe extension as standard
it was in the garage fastened to the roof.
For storage. Just to add.
Ray
