Hello, I've got a 1997 Burstner i572 'A' Class. The drop down bed feels heavy and is hard to lift back up. Looking to have the gas struts replaced . Can anyone recommend a good place to have the job done in West Yorkshire or Lancashire ? Thanks.
Very interesting, have you any idea how heavy the bed feels now with new struts?To be honest, it's time consuming rather than difficult!
Removal and replacement are done with the bed "down", sitting/kneeling on the bed. Compressing the spring is done anywhere convenient eg my shed.
I bought two long Jubilee clips from Halfords (£5 each?) and joined them to make a circle.
I placed the screw clips approx halfway between each strut bolt and tightened them equally until they were tight.
I released the bolt FURTHEST AWAY from the windscreen so that if anything went wrong the piston would shoot away from the glass.
The strut expanded a little until the Jubilee took up the strain.
Then I released the front bolt and lifted the strut out.
[Time: 10mins]
I slowly unwound the Jubilee clips, trying to keep each side approximately equal.
[Time: 10mins]
I placed bolts through the new strut and gripped them between a sash cramp, tightening it as much as I could.
Then I placed the Jubilee clips over the strut ends and tightened each side equally until it was tight.
The sash cramp was released, the peg moved closer and the process repeated until the strut was compressed to the length needed to fit back into the MH.
(I think I had to reset the sash cramp approx 4 times.)
[Time: 30mins]
The front bolt of the strut was inserted into the holder (so the windscreen would be safe if anything went wrong).
The rear end of the strut was adjusted using the Jubilee clip until it fitted into the rear hole.
In went the bolt, everything was tightened and then the slow process of unwinding the Jubilee clip started (because the clip also encircles one of the bolts so has to be totally unwound).
[Time: 20mins]
WHY my dealer thought it was a 2man-4hour job I do not know: surely they have better tools than me and more experience of how to do it. There isn't room for two people on the bed while working at the strut. I have since bought a couple of "one-handed clamps" from Lidl/Aldi which I think could make the job quicker.
Good luck - Gordon
We know someone out here in Spain that actually took van to a garage and ended up needing new windscreen plus new rear view camera monitor and sat nav the garage had to give up and they will go home early to get it sorted.?They are not easy to fit, and if you're not careful you could end up with a 2000psi piston going through your windscreen.
Please use a competent garage to fit them.
When one strut failed it needed both of us to lift it.Very interesting, have you any idea how heavy the bed feels now with new struts?
I was a bit concerned at the squeal when the bed is lowered or raised, seems to be coming from the gas strut. Using a spring balance to lift it reads over 20 kilos with just the mattress and foam topper. Bit concerned about the weight on the fixing screws holding the roof strap. Thanks for your help.When one strut failed it needed both of us to lift it.
With new struts it went up easily but I think that we overload it so it “weighs” about 15kg with original mattress, memory foam topper, sheets, duvet, 3pillows and a double micro fibre blanket. It feels much lighter without the blanket!
Gordon
Good luck - Gordon
good afternoon...cornishmanfr here, tell me please did you ever sort your Bed struts if so do you have a part number for the struts fitted, were here in France and have a problem with ours and have now found out that genuine ones are no longer available. please read my post for the details of our problem. Many thanks PaddyHello, I've got a 1997 Burstner i572 'A' Class. The drop down bed feels heavy and is hard to lift back up. Looking to have the gas struts replaced . Can anyone recommend a good place to have the job done in West Yorkshire or Lancashire ? Thanks.
