Can you stream Britbox abroad or is it prevented by the system knowing you're in another country?
Don't know about Britbox specifically but if you are using a UK based sim for data roaming the other UK channels stream ok without a VPN which will be necessary if you use a local sim.Can you stream Britbox abroad or is it prevented by the system knowing you're in another country?
