Boxer x250 help, what size is this nut?seatbelt pretensioner
eastbourne
van conversion, Peug
4 years
Just changing the seat in my Peugeot boxer 2016 plate X2 50 and I’ve come across a snag straight away. Paragraph I have disconnected the battery and I intend to take the pretension off the seat and then fit the new seat which has an existing buckle attached. The pre-tensioner will sit under the seat just to make the electrical connection. The nuts holding the pre-tensioner onto the actual seat itself is tricky, and I’m just trying to work out what size tool I am going to need to get it off, any ideas, my old non metric spanners are struggling!
C705DF15-87E5-40EE-A98F-B8714AF7637A.jpeg 5E5B348E-B191-43E8-B160-2EA5BE4E5757.jpeg
you need a torx bit to remove that bolt, the nut on the back is welded to the frame
Thanks for getting back so quick, Oh crap that explains it..... my torx bits dont stretch that far , any idea of the size i need?
Seeing as you have had the sensible answers.
It's the same size as the thingymagig located in the whatsiname
Hope that helps(y)
