I have a slight problem???? with 36-volt tool, batteries and wonder what any of you lot think, is the problem. they were to fit my electric Brompton which has only one battery now after getting a total of six altogether, now returned two batteries to the first seller and one to the local main seller, also two chargers, back to main dealer. All new both batteries and the chargers, only two went on the bike as they gave trouble on the first charging from new. I have one new battery that has not been on the new battery charger but on a borrowed old model charger.
I enclose a copy of an email to Bosch and I am still awaiting a reply from them.
The charging fault I am experiencing.
1. I have 3X 36 volt 6ah batteries for professional range tools.
2. I have a GAL3860 CV charger
3. I have borrowed a GAL 3640 Charger to check with
The problem arose when I bought two batteries online, and a charger from
a local main dealer. The batteries were half charged on receipt so I put
them on the charger, they both accepted a fast charging and the green lights
were flashing as per the manual.
I used about half of the charge on both and put them back on the charger.
Both of which flashed green then went onto a steady red light , and appeared
not to charge. The temperature was at room temp for both.
I thought that the charger was at fault so took it back and was exchanged
for a second charger. This also showed the fault. I sent both batteries
back to the seller and was given two replacements. These charged up fully
on the new charger on first charge, then red-lighted on the second charge.
Same as the first two.
I then bought another battery from the local dealer for a lot more money,
It charged OK but the second time from half discharged did the same, solid red
light only . also at room temperature. I took the battery back and it was
exchanged again by the main dealer. New one today charged only on the
borrowed GAL 3620 charger, it appears to be OK at the moment, but I am
not going to put it on the 3680 charger just in case. Telephoned the
service dept and advised to email the details as attached.
The outcome so far is that I have had 5 batteries and two chargers plus a
borrowed charger Three batteries went back to the suppliers, two
replacements have also done the same and one left that I have not dared try
on the 3680 and it might be fine, and has received a proper recharge on
the older borrowed charger. However on the 3680 charger, they seem to
accept a very slow charge. The two older batteries do not accept a fast
charge from the 3620 charger, so something has happened to those two from
being on the 3680 chargers but will take a very slow charge off that as
well
I am at a loss as to what is happening with these batteries as 4 out of
five failures all pointing to both the chargers, fast charge, not being
correct. It seems a bit of sods law that all those batteries are dud, at
but also that both chargers are dud????????????? I am at my wits end over
this matter and would be willing to drive up from Dover to Denham to
explain what has happened and ask a technician what is happening and get a
resolution. It may be that the chargers have a similar fault as they were
from the same batch, leading to the damaging of the batteries thermistors.
I am not an idiot , but I am beginning to feel like one, the instructions in
the manual are simple enough. I feel thank I might be very unwelcome at
the sellers after this problem.
What are the chances of two chargers and 5 new batteries going wrong together? Both chargers were from the same batch number from the makers, Bosch.
I think the chargers were defective and killed the fast charge circuits in all the batteries which will now only accept a very slow trickle charge overnight.
Just to comment these batteries at full retail are £245 each. so I am not happy about it at all and neither are the sellers.
well
