hi,
i have a 200ap Daly bms, i have drained the battery ( 400amp lithium ) on purpose down to check the amp hours with just the fridge set to electric on to see how long the battery would last.
the bms high voltage cut off i have set to 3.65, low voltage disconnect to 2.50.
the battery turned off when the bms showed 0% soc, although the other monitors and shunt both said the battery was at 12.1 v.
i have tried resetting the soc on the bms without any luck,
has anyone got any suggestions as to how the change the soc to its true reading.
