- Jan 31, 2016
- 2,667
- 5,187
- Hymer B534 DL (2017)
- Well travelled
I've removed my fridge, measured the gas pipe, 10mm. Went to get a 10mm compression blank to cap it off and too big...what am I doing wrong ???
My understanding (and I’m not a registered gas person!) is that in the uk gas and water pipes are sized on the internal diameter, so your gas pipe is most likely 8mm pipeI've removed my fridge, measured the gas pipe, 10mm. Went to get a 10mm compression blank to cap it off and too big...what am I doing wrong ???
That may be so but this is a German van .......do they measure the same?My understanding (and I’m not a registered gas person!) is that in the uk gas and water pipes are sized on the internal diameter, so your gas pipe is most likely 8mm pipe
Your stop end is for 10mm internal diameter pipe with an outside diameter of about 12mm, so won’t fit your 8mm pipe!
Yes true!Copper pipe is external size
