Bit of help needed Hymer indicators!
Ricardoe
West midlands
Hymer544
Just started
Hi does anyone know how to change the front lights bulbs,(headlights/indicators), on a Hymer 544..this will help me get my van through the mot...and I can spend the saved dosh on a pint for the helpfull funster..cheers lads/lassies
If stuck, you could try taking it to Halfords. They only charge a few quid for changing bulbs. I don't see why they shouldn't do motorhomes but it would be prudent to check first.
why are you changing them?
if more then one has failed it might suggest something else is wrong maybe o_O
No sorry its just the indicator bulb neads replacing and I cant figure out how to get at it !
I wouldn't take my mother in law to halfords!
Have you got down on the ground and looked up under the bumper? My Hymer is a later version but I'm pretty sure that is how to access the indicators and fog lights on mine.
If you are on Facebook then join HOG Hymer Owners Group im sure someone can help you on there
I have taken my car there twice in the last year for new headlight bulbs, which are a devil to change unless you take the engine out. They did the job perfectly well at moderate cost and I was quite happy with their service.
with bonnet off facing vehicle, on right hand side large black air filter cover. just in front of this is a large rubber bung/cover, this covers the headlamp bulb spring off the clip holding bulb, all should be self explanatory.
for the indicator bulb look further right behind the washer bottle, you should see a spring with round loop at top, pull this and lift clear. you should then be able to push complete lens with bulb out to the front.
Cheers B-well..I'll be having a butchers at the weekend and let you know.
Hi B-well..got to the bottom of it.With your help got the bulb out but nothing wrong!..started thinking the worst,so I popped it down my local garage where in a couple of minutes the man found a bad connection on a connector and fault fixed..cheers mate
Well done glad all is good to go. take care happy travels.
images
