Steve and Denise
Bio.
But you will struggle to buy any which uses that word in France or Spain and elsewhere but you can assume almost all you will see will be bio even if it doesn't say that.
The sog seems to suck as good as a lady of the night, but still smells.Bio.
But it shouldn't pong in use. Check the fan is working. When you pull the flap out you should hear it start running.
Our cassette is very clean inside, so I will rinse it out and give it a try with no powder at all,Hi Steve. If you use anything but water in a SOG it will not work properly. No bio, no non bio, no blue green or pink stuff at all.
I read the instructions some time ago and thoroughly rinsed it out ours, and hey presto, no smells.
See you at Brid for a SOG chat
Phil
The sog vents out of the roof so not a problem on the outside, but when you open the flap for a pee you know the flap is open.Is the smell outside where the SOG exhausts to, or inside?
Either way I recommend this stuff, we have a small black tank and did have occasional odour issues, our grey and black tanks share a roof vent so we dose both tanks
No smells anymore .
That sounds more like the fan is running backward.The sog vents out of the roof so not a problem on the outside, but when you open the flap for a pee you know the flap is open.
wonder if it’s the same stuff as we use.Is the smell outside where the SOG exhausts to, or inside?
No smells anymore .
Bev buys it from Amazon, not cheap but works and will dose 100+ cassettes
No filter fitted it goes straight up to the roofSomething is wrong if that is happening. Check the hose to the fan. You could also check the filter isn't blocked but I would be surpresed if it was.
Definitely drawing in the right directionThat sounds more like the fan is running backward.
SOG instructions state no liquid except water or it will not work.Is the smell outside where the SOG exhausts to, or inside?
No smells anymore .
Our cassette is very clean inside with next to no limescale, but I will give it another clean as I have a new tooth brush.If it smells it's probably due to a build up of calcium and gunge in the cassette.
Give it a thought clean with white wine vinegar or citric acid, take the mechanism out and get your toothbrush on it.
I do ours at least twice a year.
Phil
I don’t know how it works but it does ? We’ve had a SOG 1 and a SOG 2. But you have to go by the manufacturer instructions.Can’t think why, sure it’s only a fan and carbon filter, what difference would an odour neutraliser make.
A SOG doesn’t do any kind of treatment as far as I know
Phil
I have just had a read on the sog site so will give this a go And hope the smell disappears as you are parked next to us at BridlingtonI don’t know how it works but it does ? We’ve had a SOG 1 and a SOG 2. But you have to go by the manufacturer instructions.
Phil
What’s the old saying? When all else fails read the instructions.Never did like rules, poo stinks, so does grey waste water, thankfully we don’t have a SOG anymore because if I did I would be breaking the rules but wouldn’t know though as I wouldn’t have read them
Yes that’s what I thought, never used anything but water in ours with no smellsSOG instructions state no liquid except water or it will not work.
Phil
Two SOGS go head to head.I have just had a read on the sog site so will give this a go And hope the smell disappears as you are parked next to us at Bridlington
There is no filter in the roof exit typeWhen was the last time you changed the filter, the fan might be running but the filter might be blocked? I have no problem with mine.
