- Jan 14, 2020
- 66
- 100
- '95 Hymer B644
- Current van since Feb '20, before that fulltimed in London for 18 months c. 2014
Hi everybody,
We have a slow leak on the large over-dinette rooflight on our 2002 hymer camp swing.
I've had a look and there is some mastic around the exterior joint that has degraded.
Looking for any feedback on best steps to resolve this. I am weighing between:
- Remove brittle / failed mastic bead. Clean up and replace with a fresh bead of sealant.
- Remove entire skylight. Clean up both skylight and roof, refit.
- Replace skylight.
- My inclination is to try option 1 and hope that this is enough. If this is a fix for a few years, that's okay for now. However if this is a waste of time, I'd rather not bother (as it will just make option 2 or 3 a bigger job).
- If removal is required. The roof light is ~25 years old. Might it crack on trying to remove and need replacing. If so do I need to have a replacement on hand before attempting the removal.
- If the current roof light is (presumably) covered in mastic, is it even possible to clean to a standard that it can be resealed.
