Bessacarr E465 2006 Dometic RM7551L not working on low voltage 12v
Bracknell
Bessacar E465 2006
Since 2009
Hi all help needed please there I was thought I was doing a good job wiring a fan kit for my fridge
Found a permanent live on top of fridge after taking out the bowl,conected a two core wire into the block tested with voltmeter all good. Then stupid here cut the two core with snips doh no more live 12v started to sweat a bit checked all fuses none blown changed both relays, under the bonnet and fuses to be sure the only fuse I could not find is a 5amp one on the wiring diagram . Can anyone please help me find this fuse or help me solve this very many thanks for any assistance Dave aka Donk
if there is a fuse marked A on its own next to or near the 12v fuses marked 1-6 that may be the fridge permanent live that has blown that you are looking for. ,
(It also feeds the radio/cd and emc lights)
Hi all found said 5 amp fuse for 12v low voltage side of my fridge fuse had blown
The fuse location is behind the control panel about six inches to the left
Access is via the cupboard take righthand corner facia out and pull gently and hey presto a fuse holder on its own hope this helps anybody that has the same problem as me
