Rapido on a Ducato (cbe boxes)
my 2 banners need replacing this year. throws up a few questions.
my preferred choice would be 3 exide gels.@lenny hb but
pocket and location says 2 can i sensibly add 1 next year?
the current locker can hold 2. the 3rd would have to be 3 foot away under the passenger seat.
how would you connect them together for charge balencing?
the passenger seat currently has a tool box undernearh, it is located with a lug into a receptacle on the floor.
any idea as to how this is fitted/ located to the floor and can it be transferred to the drivers side?
other things to add: dont concider mentioning Lithium.
inverter: dont use one generaly, have a 400w aplication once in a blue moon (washing machine) the slow cooker is run off cab battery on the move.
solar 550w on 2 votronics controllers (direct to batteries) 330w and 120+ 100 on 2nd. (330 added last year) undecided as to whether to use series or parallel, thinking series as doubling of voltage is of more use in non summer months versus shadowing effect as there is still the 330w one. or is this thinking flawed?
next question
AES fridge, is it worth the agro setting it up? do i need to connect both controllers to the fridge. i thought the 12v supply was from the alternator/ cab battery not the hab lesuire side, does the fridge then need a supply from the hab?
Sorry for so much info, questions in one go
next question
