Around about a year ago I upgraded the 12v system on my motorhome changing to a lithium battery
280 amp Fogstar drift battery
Renogy 30 amp battery to battery charger with 300 watts of solar
Renogy 2000 watt inverter
Every thing has been working fine although I only ever used around 50% of the battery
Use is normally microwave kettle and charging bike batteries phone batteries
I have during the last couple of trips powered the fridge through the inverter
I have been away for a few days and decided to get full use out of the battery so during the day I have had the fridge powered through the inverter and when monitoring the apps both Fogstar and Renogy the battery was discharging at around 2.5-3.6 amps due to the solar generated
The battery had dropped to around 42% this afternoon and being as we are heading back home tomorrow I continued to use the inverter then suddenly the inverter alarm came on and the fridge lit up on the gas the Fogstar app reported over discharge and shut down the Renogy app reported the same over discharge of leisure battery
Not sure what happened as the battery should still have plenty of power
The renogy app has shown the minimum voltage today at 8.9 volts maximum today of 13.8
The Fogstar app is allowing discharge at the moment ( could not turn that on earlier ) voltage is currently 11.2 but no sun at the moment so no more charging cell voltage low 2.759 Hi 2.834 Diff 0.075
Any ideas
Any ideas
