Bart
I'm looking to know what size of fuses I should use in the link cables between my batteries.
These are linked using 25mm gauge welding cable
3 Varta LFD 90 batteries,
Max loads come from microwave via inverter which draws about 130amps ( it has its own 150 mega fuse for it)
Previously I used 60amp fuses....i think.... but should I be using smaller ones??
Also in installation is 60amp b2b charger ( fused with 80amp fuse)
And 400w of solar via a 30amp victron controller fused with 30amp in line trip/fuse.
So what size fuses should I use
