I have a single 100ah domestic battery that is a bit old, I was thinking to replace with new one, is it ok to get two smaller ones (2 x 75ah rigged together) so i up the AH and get more power (do not have solar panels)? Thanks
I know what you mean but to someone who doesn't know about batteries it may seem to be saying join one negative on one battery to the positive on the otherWelcome! If you have the space one bigger battery might be simpler to fit but you can certainly fit two smaller ones. Wire them in parallel and if you can connect to the positive on one battery and the negative of the other. It's not the end of the world if you can't easily do this especially if you don't use a lot of current.
