Bailey Autograph 79-4 2019 EHU not showing connected
Paulandcol
Own a van
Hi. Our van gas been sat on drive with EHU connected over winter. Noticed that the EHU icon was not showing on display above door. All 230systems ok. 12v barely alive. Leisure Battery was flat, would not recharge. New fitted and 12v now ok. Suspect 230v to 12v charger at fault. Solar unit appears to be ok VB and LB sharing 50/50. Any advice on location and remedy please.
The charger is in the top of the 'power distribution unit' - 2 screws to remove cover and then it lifts out. The EHU icon on the control panel is driven by the white 12v signal wire from the charger so, yes, it would appear that your charger isn't working. Check that its 240v circuit breaker on the front of the PDU hasn't tripped of course.
I had the same issue on my previous Motorhome which was a 2015 Autograph and the charger was blown
Yes this was also on my list of faults i think number 54 ! Replaced under warranty
