Was it as simple as that? I think you would need a resistor in series to drop the voltage. Most LEDs have forward voltage of less than 5V, and can't be connected straight across a 12V supply?I just connected an led to the light wiring at the switch. The led was on length of wire so easy to fit
You can buy 12v led bulbs from Amazon for interior lights/number plates so no resistor required. A normal little led bulb is 2-3 volts so yes you’d need something to lower the voltage, a resistor or dc step down buck from eBay would do it, used a dc buck quite a few times to get 12v to 5v for dash cams.Was it as simple as that? I think you would need a resistor in series to drop the voltage. Most LEDs have forward voltage of less than 5V, and can't be connected straight across a 12V supply?
If you look at the spec details you can see there is a small resistor incorporated into the attached wires, so these LEDs are OK to connect across a 12V supply. As skylinersi says, easy to fit.You can buy 12v led bulbs from Amazon for interior lights/number plates so no resistor required.
