Awning help please
winchcombe
swift sundance 630g
loooking at a Kampa Rally Air Pro 260 awning for a caravan 2019 can they be used on a fiamma f45 to attach? any advice would be great.
Depends if it’s the correct height but the Rally Pro has both sizes of beads so okay for a Fiamma.
not sure will ask do i measure from the fiamma 45 to the ground ? cheers
You need to measure from the groove in the Fiamma to the ground and see if it’s within the range of the awnings recommended height.
she said 250-265 i have a swift sundandce coach built thanks for info,
If your awning is fixed to the side of the van you will have a gap between the awning and the van, you may be able to use Kampa Limpets to close it though.
yeah might be better to get the correct motorhome awning,only need it for when we are away in bad weather so the f45 comes in and just have awning for bit more room, funny as i said i would never have one.
The awning you have mentioned isn't tall enough to fit your Sundance, you will require the Kampa Motor Rally Air Pro XL for the correct height.
I’ve just bought one xl hopefully be ok paid £260 so hopefully not wasted money
