Average 11.5 v all weekend
Derby
Autotrail Cheyenne 840 SE
Hi all, could I have a bit of help please?
First time without Lecky last weekend, 3 days at the Newbury show. We are not big uses of electric just the usual pumps, lights, couple of hours tv and that's about it. On the second day we needed a bit of heat so popped the Truma on when the fan tried to kick in the lights would dim and the fan hunted on and off.
Voltage dropped to about 11v. when there is nothing on we still seem to be using 3amp's is this usual?
The M'home has been standing since Sunday and just checked voltage and it's showing 11.7v so doesn't seem to lose any power.
The leisure battery is a Numax 110 amp and approx' 1 year old.
I am thinking about fitting two new batteries as above and two 120 watt solar panels.
Now the Sargent box in the M'home supports solar up-to 120w what would be the best configuration to accommodate both panels?
Thanks in anticipation of your help
Colin
why would it be any higher if nothing is charging it.
12.2 v is only 25% charge level - below that your battery is not very good at all.
It should be 12.7v or more when fully charged.
Solar panels will solve most of your problems most of the year but your present battery looks as if its knackered.
Note - I am not a qualified electrician.
First, I wouldn't completely trust the display panel until you've double-checked it with a multimeter. What is the voltage reading at the actual battery terminals using a multimeter?
Having said that, the symptoms are what you'd expect of a low battery. The 3 amps when nothing is supposed to be on is not usual, maybe other Autotrail owners can say what the expected value is. 3 amps will more or less flatten your battery in 24 hours. If it's a real value, not just a faulty meter, then it needs to be fixed.
For comparison, 3 amps for 24 hours is 72 amp-hours. You'll be lucky to get 100 amp-hours per day out of two 120 watt solar panels, so that won't really solve your problem
Some factory gauges can be as much as .5v +/-, so it has been suggested previously to measure using a voltmeter at the battery. Also if the solar has been wired through a factory consumer unit, you can also loose efficiency that way, but never would I have thought it would be that much.
All these things aside, 11.7V is low for the charged state of a battery and certainly needs more investigation, as at that sort of voltage, you would be at roughly 25-30% capacity and repeated, would certainly reduce a typical lead acid leisure battery's life.
My advise is to have it either checked out (both battery and solar output), or using a multi-meter and check the voltage at the battery and check the output of your regulator.
Hope you get to the bottom of the issue (y).
