Autotrail cheyenne 590 1999
Royarn
Since 2013
Hi All, recent problem with my mo ho, the toilet flush has stopped working, (pump isn't running) I've removed pump and tested on the bench also removed the tray with micro switches and tested that they are working, all ok. I'm assuming I've lost supply to them somehow but the only fuse that sits above the cassette is OK. I don't have any wiring schematic so have no idea where it gets supply from. Help !!!!!.
Thanks Roy
Is there any voltage at that fuse above the cassette?
Are all the 12v fuses ok on the main power supply?
Have you looked on the auto trail website as they supply old manuals on there?
Hi Mike, thanks for suggestions, no voltage at fuse, and unable to find manual for my van. Read a couple of nasty problems with corroded wires under shower tray etc ugh
Roy
Might be easier to run another live feed to it, I had a similar thing with my satellite. I reckon a mouse may have chewed through the wire so just ran another feed to it.
Try Sargent Electricals website, if they did the leccy they may have a schematic as there are loads on there for Autotrail
ditto...
Supplied me with a wiring diagram for my 2012 apache 700 when i asked.
Hello. I have a 1997 Cheyanne 584 for which I have a wiring diagram if that might help
I have just had a lookat the diagramand it does say it's for all Cheyannes of that ilk, so i'll post itand you can decide if its of any use to you
This would likely be useful if you know a way to send a copy I would be most grateful.
Woops you already sent one, shows toilet connections as well ,now I can try chasing it, thanks Olly.
