Autocruise Stardream
Dundee
Elddis Autoquest 195
since 1975
Hi mate has bought one of the above Moho ,a 2009. We have looked everywhere for an on/of switch fo 12v roof lights but cannot find one !!All the lights seem to controlled by master switch on control panel about door !
So when going to bedthe only way to turn lights off is by master light switch plunging whole Moho into darkness!
Can anyone help with suggestions too turn off roof lights but leave power too under locker spot lights.
T.I.A.
Might help if you can post a picture, but if it’s a small spot light, maybe pushing the light fitting up. We have two of these in the roof over the drop down bed at the front.
Hi alan, , there is 6 led down lighters on a roof panel but no on/off switch ! Have to use master switch .
Spotlights under locker have own switch but when you switch of at the door switch every light go off !!
Pictures will help.
Alternatively pull lights down and wire up individual switches - sure you can find something small and unobtrusive?
There is likely a separate switch on the main control panel - a picture might help.
Our Swift panel has a button for the lights main switch and another that just controls the main overhead lights. Perversely this latter will switch on the main lights even if the lights master is off!
We have a 2007 Stardream. If it's got the same oval domed lights then each one has its own switch built in. Its a small rocker switch in the middle on one side. Bit weird as flicks the wrong way to what you'd expect so doesn't feel like it wants to move at first.
Called a Lumo Coronet
Post a pic if different in case someone has replaced them with something without switches.
Our control panel turns them all off too but never need to use it to turn them off at night.
Hi,
I have a Stardream on my forecourt of the same age and have just had a look..
The factory lighting does have a black on/off switch.. They look slightly different to the one posted above but same concept.. If they aren't the factory fitted lights and have been replaced without an on/off switch then this would explain why you cant turn the lights off.
James
