Auto Trail Frontier Comanche .
I am a newbie
.Has any one come across a switch on right hand side of steering Colum above the little shelf.
Non standard thats for sure. Switch it and see what happens ?
Have done but cant find anything, it is same switch as the one fitted for media pack.
Might keep hab electrics on while engine running, might override reversing camera to become cctv with ign off, might disarm internal movement sensors for alarm if you have dogs. So many options so little time ?
This switch is for the bike loop on your alarm.. you should have an electrical connector under the rear of you MH... a wire loop fits into this to wrap around bikes etc... the switch that you mention then activates that circuit..
It could be a switch for a bike loop, switch it on and set the alarm see if it chirps a fault.
I can’t get the picture up, but it could be the switch for the reversing camera. You can switch it on to check behind with out moving.
Could be alarm on but habitation door sensor off, it will chirp a fault when it's switched as Jim said above.
Is it not that the reverse camera is live all the time on autotrail and can run the batteries down so some have an isolation switch. Need someone clever. Haha
Will have a play with it and see if I can find anything it operates.
Did you get to the bottom of the switch Ally1858
Know I haven't been to MH yet to have a look.
It's an general accessory 12V isolation rocker switch probably for the rear view camera.
Ye there is an identical switch on the control panel for the media pack, so think its been fitted at the factory.
DIY kill switch? Run the engine stationary and then flick the switch?
Oddly, I have the same switch in my Autotrail but hidden in the glove box
I have tried to trace the wires but no luck and have long since given up !
Just bee to MH and switch has nothing to do with reverse camera, alarm nor engine cut out.
