Archiescamping for Android
PaulB
Cumbria
Vantage Neo
Since September 7th 2016
I've downloaded the app which looks excellent value for money. On the web site there is a link to instructions for how to download off line maps to an external sd card. However on opening the link it downloads a .doc file which if I open in wordpad or note is just symbols and random letters. Can anyone tell me how to download the off line maps to my sd card. Thanks
You do it from inside the Android app, launch settings scroll down to the general tab, click map select mapsforge offline from there you can select map, download the map and the install directory.
Thanks @Steve N Tracy I've done that but it downloads the map to the device storage not the external sd card
Yes it looks like the latest versions of Archies only recognize the main memory of the phone, so to get round this I will have to move the mapforge directory to the SD card using the file explorer and then copy the relevant map I need back to the parent mapforge directory when if need to use it offline, bit of a pain but as I have unlimited data on 3 I should only need to do this if there is no signal.
One more question if I may, when clicking on "navigate me" on a campsite poi in Archiescamping it opens in Google maps, how can I change this to Here We Go or Sygic? @Steve N Tracy
That would appear to be another option that has disappeared from the options menu, I always used to use Sygic but now there only appears to be the google option!! certainly not as good as it used to be.:(
I've solved the problem. If you go into your phone/tablets settings then application manager then maps google and either clear defaults or on my tablet there is then an extra option called go to supported urls select always ask and now when I click on a campsites "navigate to" icon I get the choice of all possible mapping apps on the phone or tablet.
Thanks Paul, that has given me the opportunity to use Copilot for caravans to route using Archies.
Regards
Steve
