Anyone know what make these lights are
Ipswich
RV and PVC
30 years
Little spot lights doesn't seem anyway to replace the bulb.
I`ve got 2 Reading lights which are Inset, as far as I can see when they expire you swap them out!. tiny little lamps. but bright!!.
The knurled bit at the back does about 1 turn and goes tight but doesn't seem to do anything, maybe a bit of bf and bi is called for. ::bigsmile:
Maybe they are non replacement LED s
Used this company before about five days for delivery to uk
No idea if you can get the LEDs separably
The knurled bit at the back is a dimmer. Don’t think you can replace the bulbs but complete units are fairly cheap on flea bay. You can also get them with two usb sockets built in to the base for about 25 quid.2D7FD010-A08D-4337-8CBA-18EB01BA2E45.png
I ended up getting a replacement in our last motorhome (bessacarr). I was unable to get one exactly the same but got similar on ebay.
From what I could see of the failed one the bulb bit could not be replaced, at least not by the time I had finished with it.
iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiit’s lump hammer time. :clap2:
Humble pie time guys, you have to turn them on via the Sargent digital panel.:doh: RTFM time to find out how turn the awning light off. Whats wrong with a flipping switch!
Prima link
Check the link out, Bailey use the same style.
You cannot replace bulbs, Magnum Motorhomes have new lamps with fittings for around £12 each
If any of mine go I’ll be changing the two in the bedroom for the type with a usb on and keep one of the old ones as a spare.
