Does this go on positive or negative side?
All my negative wires under bonnet are brown...
Im sure at one point it was on the negative post. I had the battery changed the other week and it must have snapped when the garage took the battery out. Having said that, thats just me assuming!! wonder what would happen if i fire it onto the positive side?!!CAUTION - STD UK auto wiring suggests...
Brown normally positive plus there seems to be a dirty great fuse in-line. Black is negative, or ground. Questions:
- Where DID it live?
- Assuming it's broken off, where is the other end of the broken spade terminal connected?
- Where does it go?
- What is the vehicle?
If it isn't meant to be on Pos it would trip the resetable fuse/breaker in the black box.wonder what would happen if i fire it onto the positive side?!!
what's the worst that can happen if i fire it over to the positive side i wonder.......?!!If it isn't meant to be on Pos it would trip the resetable fuse/breaker in the black box.
The breaker makes me think its 'positve'.
Connecting to Neg will do nothing if a second wire is already connected to negative.
no its a N&B flair 2006 on an iveco daily.Hss the vehicle been converted from another use? Police van / ambulance?? Mine has lots of extra cables are remnants of a previous life.
Cheers James
I just reread your post. sorry for asking the same question twice after you answered it!If it isn't meant to be on Pos it would trip the resetable fuse/breaker in the black box.
Fire may be the only solution!!!The broken off bit must be somewhere. Bearing in mind how chopped around this moto has been I would hang back bn until I found the bit it snapped off or made really sure what it did.
You knew it was a challenge and it will be lovely once it's all sortedFire may be the only solution!!!
Looks like a resettable fuse/breaker to me. You can see the reset lever in a shallow recess at the bottom.Is that black plastic thing a Midi fuse holder?
How would I know that? What reading would it give?I would put a multimeter on it & see if it’s a direct earth
Bonus thanks. Ill order some 30 & 50 and start with 30 amp!Looks like one of these to me.
which takes a Midi fuse![]()
MIDI fuse holder ALT/FH560-02
function passpara(){return '&id 771203&itembgcolor 0xFFFFFF&bordercolor 0x000000&storewindowbgcolor 0xb8d6b6&toptextcolorwww.altecautomotive.co.uk
But Mega fuses look much the same, only bigger in length with a larger hole, so check first.![]()
MIDI fuse (30 - 200 Amp rating)
Range of MIDI fuses Bulk deals available for packs of 50, 100 1000. The MIDI fuse is available in the following amperageswww.altecautomotive.co.uk
