As I previously posted about my fridge on the Hobby 600
The igniter is not clicking as it should do when the switch is turned on.
I've managed to get to the wiring on the top of the fridge, the easiest way I found was to remove the gas hob.
Testing the wiring to the illuminated rocker switch that operates the igniter, there's one at the bottom that goes to earth and there is no live feed to either of the two other wires.
The wiring to the other side appears fine and the 12 volt side of that comes on when the engine is running as I believe it should do.
Has anybody any idea where the 12volt feed for the igniter comes from. I think that it must be a permanent live feed as in the past when the gas has run out and the switch is on it clicks all the time until the bottle is changed over or the switch turned off. would it be a direct feed from the battery, leisure battery or somewhere else. I don't seem to be able to find it and don't really want to be completely stripping the van out to find it.
