- Aug 11, 2019
- 73
- 51
- Swift Kon Tiki 679
Hi everyone I have a swift KonTiki 669 with 500w of solar, 4kw inverter and Victron solar controller , B2B and mains charger.
I have two 110 AGM cheap Halfords batteries about 2 years old. I also have a vanbitz device to keep the engine battery topped up. Vehicle split charge relay disconnected and factory mains charger are turned off. Have not worked out how to wire the step to autoclose and put 12v on fridge after split charge disconnected - actually it stopped working just as was fitting b2b that’s another story!
The motor home has a lot of electrics TV, and we use the car audio for surround sound. On a really dull day when solar is down to less than 50w we can discharge in a day with heater blower on, tv, audio etc. Interestingly the engine battery also discharges to around 11v so suspect it needs replacement (it’s original and 12 years old). Most days we get 150w easily and in full sun we get 350-400w from the solar setup.
ive checked for current leakage ans can get it to 0 if I turn everything off. It’s amazing how many device pulling around 200mA we have
Most days in Uk have more than enough solar for us it is really just the odd overcast day. It was much worse when we just had 300w of panels - roof cannot take any more.
My question is if I wanted to replace the two 110A agm batteries with Lithium etc what could be fitted in same space to maximise storage?
current batteries are under floor in dedicated box and am aware of cold charging issues. I think I could live with this.
Am interested to know what people physically swap two 110A leisure batteries when they go to lithium. Lifepo4’s get good reviews but how many of say the 100amp ones can you fit in the space? Weight saving will be welcome but would like to know how many I can fit (budget permitting)
