Allegro Lights
hobson
My partner and i have recently bought a Tiffin Allegro with the intention of full-timing, however the lights on the RV are about as bright as a victorian gas lamp! fortunately the site we are on has a great RV specialist, unfortunately though he has had a look at them and told us that the bulbs only have a single filament, and the last time i spoke to him was unable to source some brighter ones (assuming they exist!)
So we're guessing other Allegro owners have had the same problems and thought this might be a good place to get some answers!
so please, if anyones got any ideas let us know, as i don't really want to resign myself to only driving in the daylight! :BigGrin:
Sorry, can't help with sourcing lamps, our RV has poor headlights too, my solution was to replace the 'running' lights on the bumper with a pair of good quality high power driving lights..
Jim
Posted via Mobile Device
Hi what type of lheadights are they?
My 98 Allegro had sealed beam units when one packed up I was able to source different bulbed units from a helpfull motor factor shop and then able to use higher powered bulbs, I had to only slightly modify the back of the units remove a little hoop I seem to remember:thumb::thumb
This was the Tiffin Allegro
Hence my forum name:Rofl1::Rofl1:
Regards Pat
R-V Lights
If you have the 4 Lamp system then there may be a solution in the LUCAS range. I have a 4 lamp (Dip/Main) on the Odessa and the units are LUCAS with Halogen Bulbs.
I also havs a spare (L-Hand set) which I can swop for "continental" use.
Pete
poor headlights
Jim
Hi Jim
Regading poor headlights there is a cure if you take a look at my web-site winamotorhome you wil notice on the home page i refer to bright headlights, If your electicly minded like me then it's not a problem, Otherwise you will need an automotive person to carry out the conversion, if you need any advise on how to carry out the work please let me know,
Stan.:thumb::thumb:
Hi i have just sent jim a message and asked him to look at my website winamotorhome and on the home page you notice under features the ultrasport has bright headlights,
if you would like to have your rv specialist contact me i will be able to give him the tech information.
Stan
These are the old units I recently replaced with new from a local Lucas dealer who got me original (Hella) units for a Very reasonable cost.
I Just ordered 4 "Blue" Halogen units for them and bought new connectors for the "Bulbs"
Amazing lights now.:Wink:
Lights
"snap" mine are from Lucas, but just about everything else is the same. the Hella Units could even be Cheaper.
pete
Thanks for the replies everyone, i've briefly spoken to the RV specialist, and i know he's been on the site and seen the post, and he's still on with it searching for an answer. i've also mailed Tiffin in the states to see if they have any ideas, i've had a mail back asking for the chassis number, so i'm hoping they might have a solution.
regarding the actual lights, they are different to the pictures on here, they're a wider shape which curves around the sides, as soon as i install the software for my new camera i'll put some pictures on!
Do you have the make and any numbers that are on the glass lens please?
Any Pics would be brilliant.
Hope you get it sorted.:BigGrin:
Have you tried the Tip given by Stan:thumb: it seems very logical and i will be trying it out as soon as the weather and time permits
Geo
Righty ho, i've got the pictures and finally got them onto my computer, so here they are, the one on the far right is the back of the light where the bulb fits, hope these help. :thumb:
and now that i've got the numbers off the bulb i've done a quick search and come up with these: any thoughts?
just to let you all know, i got a free pair of Halfords Superbright bulbs, supposedly 50% brighter, and have just tried them in the dark, i'd say they are about 20% brighter, so they have made a difference, but i've been reccomended Osram silver xenon ones, they're apparently the brightest you can get apart from 100w rally bulbs, which aren't road legal, so i'm ordering a pair of the osrams and i'll let you know how they go.
Oh, and i got a reply from Tiffin, they can do all the main parts, (new light fittings and lenses) but not bulbs. :Smile:
well i looked on the site and here's what they say:
50% more light on the road
UV protected and suitable for use in plastic lenses
Fully E marked and road legal
Improves visibility at a distance of up to 75 metres
this is for the Osram Ring Ultra Xenons, which i'm going to order when i've typed this.
i'll let you know how much better they are, might save you buying them if they're not worth it! :BigGrin:
Good luck with the more powerful ones.
Bulb technology has certainly progressed over the last couple of years.:thumb:
Mine are excellent and I'm well pleased with the transformation from the old "glow-worms".:RollEyes:
Shiny new bulbs
Just to let everyone know, I got the Ultra Xenon bulbs today and have just fitted and tried them in the dark.
LOADS better! even brighter than the Halfords (supposed) 50% brighter ones.
they give out a much whiter light than the standard bulbs too, i tried the standard ones before the Halfords bulbs across the site we're on, across from us are trees about 60-70 foot away, with the standard ones i could barely see the trees, the Halfords ones lit them up a bit, but the Ultrs Xenons lit them up really well.
So I'd highly recommend them, especially for the sixteen quid they cost.
I am now a happy bunny! :BigGrin:
Hi Hobson
When I bought my Tiffin Allegro I had to travel 220 miles straight off to get it home, the brightness was one thing I didn't check before I bought it.
It soon became apparent that they were well under par on my journey home. When I tested the voltage at the lights it was only
10 volts.
The way I solved the problem was to put relays on the headlights and add two spotlights all have their own separate relays,
now I can see as well as I can in my car and I did not change the original bulbs.
It works for me, try it. there is only the cost of three relays to lose, but make sure that the relays are 30amp or you may melt the fuse.
Bigrog98http://www.motorhomefun.co.uk/images/smilies/thumb.gif
bit late now, but reading this post today, i would also go along with checking the voltage at the bulbs with engine running. it ought to be 13-14 really..
my car has thin wires to the main and dip bulbs, and these nick some voltage.. I did the thick wire and double relay mod and it's helped and will help osrams or whatever in the future..
the original wires to dip and main become the switching wires on the relays :BigGrin:
dont forget a nice big earth
John
