7Hvn
Took our 2009 tag axle (ALKO Heavy Chassis) for its MOT last Month and it failed due to inefficient hand brake:
Foremost Axle: NS 200, OS 160.
Rearmost Axle: NS 70, OS 100.
On investigating the rear hand brake mechanism, the cables were shot. As an aside the rear pads were pretty low and disks tatty.
Purchased these (very expensive) and fitted them along with new handbrake shoes, discs and pads on the two rear axles.
Following the steps:
At first I thought my torque wrench must be out of spec so I used a 2nd and the same happens.
Is 15Nm definitely correct for an ALKO Heavy Tag Chassis?
I then tried, with the handbrake still off, slackening the splitter tensioners such that the wheels would spin freely. I got this to the point where one half a turn more on the tensioner would change from a free spin to the start of binding on the 4 wheels.
Queue the 20 minute procedure to get her off the axle stands and back on the tyres (right faff). Quick back and forth on the drive (no road jaunts without an MOT) and it seems to hold it ok. Now, when I reverse or drive up my Milenco Quatro ramps and test at the 6th click she wont hold.
I can't see a world in which I can have an operating hand brake that can lock the rear axles at the MOT station (and crucially keep the van on the ramps on a pitch) and have them NOT binding whilst driving.
I'm sure a few of you will have done this job yourselves on a Tag or do it for a living - Care to share your pearls of wisdom?
What am I missing? Are the above instructions correct for a Tag?
Any advice appreciated... Thanks in Advance.
- Release the tension on the handbrake cables by slackening off both fore and aft 'cable to rod' splitters.
- On each wheel separately adjust the shoes so that the wheels are fully locked then back them off 5 (+/-1) teeth on the adjuster. Make sure they aren't binding.
- Ensure the 'handbrake lever to mechanism cable' is tensioned such that the mechanism lever is detached from it's rest.
- Set the handbrake lever to the 6th click.
- Tension the fore, then aft, splitters to a torque of 1.5daNm aka 15Nm.
