Alde pump settings
Anglesey North Wales
Adria Twin 640SLB
Since 2010
there are two settings used to drive the circulation pump constant or driven by thermostat.I have mine set to driven by thermostat up when yould you need to use the constant setting ?​
The constant or "continuous" setting would be used when you want a more stable temperature as it removes the on/off cycles of the pump and runs continuously modulating the boiler temperature to control the room temperature.
Result, = no hot water when the heating is up to temperature,
When to use, = Never,
Never seen the need really, unless the thermostat fails. I suppose like the central heating at home there is always a “continuous” option
