Alde 3010 Panel Resets when off EHU
West Sussex
Burstner Nexxo T740
since 2008
I parked up at the weekend and after about 30 mins decided to put the heating on. Switched on the panel and all was ok. After about 20 mins the Panel went off and the heating stopped. I turned the Panel back on and the heating came back on but the time was no longer showing on the screen. Went into settings and it had defaulted to 00:00 and Monday with the clock set to off. Set it back correctly and about 10 mins later it did the same thing. Gas is fine and Leisure Battery measures 13v. It works fine on EHU - panel stays on.
Anyone come across this before?
Not experienced the same fault, sounds like a faulty 12v connection,
but give the guys at Alde a ring they are generally very helpful.
Ed
We had the same problem, if I remember correctly Alde replaced the panel ... it has still happened a couple of times since.
Ed
Would second that.... The guys at Alde fixed an intermittent problem with mine - he had seen it once before and that occasion it was electromagnetic interference; a ten minute fix. Serviced the system and changed over the fluid as well. Very good service from them
I have had an e-mail chat with a Guy there but am not convinced as it started off being normal expected operation when the 12v keep alive voltage switches from the car battery to the leisure battery then changed to it being always run off the leisure battery. I wonder about a loose connection but I can switch it straight back on after it resets so not sure. It is booked in at Alde for the fluid change in April but would like to get it sorted before then. I will check the connections at the weekend.
Ive had the same thing with a 3020 system and panel. Bloody annoying when you wake up in the middle of the night and wonder why you are baking hot, only to discover that the panel has reset as per the op and as you had it set at 20 or whatever it comes on and heats up!
I might prefer that to it going off completely - mine defaults so no heating.
Its the 3010 touch screen.
sorry should have added my question was to say I have upgraded mine and have the original controller you could have tried as a freebie spare part, but it the non touch screen version ?
best of luck, but I would involve Alde we had a service last year when they fitted the upgrade controller they are very efficient and by far the best company within the Motorhome Industry I have found to date
if marginal on warranty I suspect you might still get a replacement ?
