AL-KO Click Fix steady legs
Luton
Coach built
8 years
Does anyone know if it’s possible to fit AL-KO CLICK FIX Mechanical Legs
To my Autosleeper Cotswold
I would like two on the front and two on the rear if at all possible
Regards
Gordon
If it's on an Al-Ko chassis, chances are the rear mountings are pre-drilled and ready to go. If on the Fiat chassis, you need to make brackets, which is what I did:-
https://www.motorhomefun.co.uk/forum/threads/drop-down-legs.130506/
The front ones aren't so necessary I think - but if you want them I *think* I remember that Al-Ko do a version which bolts to the standard Fiat jacking points.
Hope that helps
