Hello all, any ideas of how to sort an air lock in the water system please? Also since finding this the pump runs constantly.
We're trying that, thanksAssuming it's a pressure switched pump like a Shureflo.
Close all the taps, make sure there is water in the tank. Then open the tap nearest the pump just a fraction it can take 5 or 10min to bleed the air out. Once you get a dribble of water coming out repeat on other taps.
Oh yes it does and it won't clearDoes it sound at all like the water is trying to get through. Taps should gurgle and splutter a bit and make a bit of noise if it is trying to put water through.
This is new to us, no idea how/where to adjust pressure switchAre you saying water is flowing? If that is the case it may just need the pressure switch adjusting
I would stick with that. Sometime I need to really play around with it. Hot to cold, off and on...cover the tap head with my hand so it builds up pressure then release etc.Oh yes it does and it won't clear
Yes!I would stick with that. Sometime I need to really play around with it. Hot to cold, off and on...cover the tap head with my hand so it builds up pressure then release etc.
At least we know the pump is trying to send water through.
Gotta ask...definitely got water in your tank?
Adjusting the screw made no difference. We have an appointment at Batteries and Solar in Plymouth tomorrow, I think we'll let them sort itPhillips screw on the end of the pump, to set you should turn a tap partly open so just a small flow and adjust the screw until the pump cycle off time is more than 2 sec.
if it's running all the time regardless off any adjustment it's got to be an air leak. Leaks can be so small they allow air in but no water comes out.
A good starting point is the pump check the screws are tight that hold the pump onto the motor and check around the pump for leaks.
Next step if no luck take the pump off the motor and grease the mating surfaces of the two halves of the pump with food grade silicone grease, when reassembling use a removable thread lock on the screws that hold it to the motor.
