Air bags
Cornwall, UK
A class pegaso 590
4 years
Hi has any one have information on air bags for the rear axel? Are they worth it best make of bag 2 valve with gauge or without and just carry a compressor or a compressor fitted any info please
the cost it depends on what chassis you have. There are several self fit kits on Flea bay or at Marcle leisure from around £280 upwards.
I fitted a set off ebay just to improve ride and stability. good value and result at £280.
i would suggest if you fit yourself you fit separate lines to either side and adusting the pressure by foot pump or even hand pump is not that difficult. i use a cheap 12v tyre inflator plugged into a cig socket in a locker.
How do you pick the size air bag, or do you just ask for a kit for a fiat decato motorhome
You simply ask for a kit for your year of fiat ducato.
Assuming it has a std fiat chassis.
If it has an Alko chassis then you need an Alko kit. And they are normally more expensive
Thanks for that
I fitted Easytop air suspension to our Elddis about two years ago.
It was purchased direct from Easytop in Italy and it arrived within one week.
(This was pre Brexit though)
A lot of people on here have used Easytop as it is very easy to fit.
It clamps onto the springs and there is no need to remove the U bolts as required with some other systems.
The kit contains the bellows and two gauges. It holds pressure well and can easily be topped up with a 12V compressor or bicycle pump.
A big improvement in handling/stability.
As above, it will only work with the standard Fiat/Peugeot chassis. (i.e. not Alko)
Thanks for that
