Air bag warning light . (1 Viewer)
Bluethunder
107
142
Peterborough
Elddis Autoqest 155
6years
Can anyone give advice,our motorhome is in storage and was last run just before Christmas,no problems when I parked her up in storage,I went to check and run her the other day but the airbag light didn't go out on starting,I had a word with a garage on the phone and they advised me that because airbags are so complicated it would be between£200_£500 to fix ,
Any ideas,thanks in advance
Aug 18, 2014
23,854
134,457
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
I seem to recall that low battery level can cause the light to come on & cause an air bag ecu falt.Someone who remembers will be along to clarify how it gets repaired hopefully
SandraL
1,373
985
Somerset
Hymer b694sl
Any help, crashdata seem to be a company that will sort you out.
574
250
Guisborough North Yorkshi
Malibu T410
Since August 2008
Hi - if you do a search for Crash Data - they test/refurbish the unit - Our light came on for no reason atall whilst driving - I looked up on Crash data site and on here how to remove - sent it off; couple days later got it back, put in and since then no problem - think it was around £50 ish for the repair - the fault they said was down to a flat battery - but that didn't seem to fit - but doesn't matter - they fixed it and were good to deal with
Hope this helps
473
333
nottingham
5 years
Had the same light come on , unfortunately it was as I collected it from storage to go for service and MOT. Had gone off by the time I arrived,but when they restarted it was on again. Automatic failure. Had to have it done.
