Hi all you knowledgeable PV bods out there! I’ve bought an EPEVER Duo Racer MPPT charge controller, I have put two additional 120w solar panels on the roof of the MOHO (total of 3 now) and I’m planning to connect up as per wiring diagram from EPEVER. I’m going to connect the panels in parallel to each other with a 10amp diode on each of the +ve leads of the panels before they are joined together with a “three into one” connector. I’m going to connect the EPEVER unit directly to the lithium leisure battery as “Batt 1” and directly to the vehicle starter battery as “Batt 2”. My question is what should I do with the mains charging from the Sargent EC500? Can I leave it alone and when it’s plugged in to the EHU it’ll charge both batteries and the EPEVER will also charge them? Or should I incorporate some switching that switches off the EPEVER when I’m on EHU? The EPEVER diagram shows a “breaker” in the +ve feed from the solar panels, should this just be a simple switch? Or does it need to be a 12-18v DC breaker?
Cast some knowledgeable light please as I don’t want to blow up lots of expensive components! Also advise if I need to buy more stuff!!
Thanks in advance boys n girls!
Russ
Russ
